Kentfish1966
I have been asked to help the Amish design log beams for a log home. They are using locally cut white pine trees for the logs. Does anyone know what design values I should be using for the bending strength, shear strength, and modulus of elasticity? I thought to use the values of #3 visually graded lumber but this would fall more into the beams and stringers category. In Wisconsin, because this is ungraded lumber, we are supposed to use values for #3 material. If you look at beams and stringers there is no #3 grade. Any assistance would be much appreciated.
Thank You,
Kent.
Thank You,
Kent.
