I have here in my hand a structural steel spec that says in addition to pre-tensioning (structural) bolts, Loctite Threadlocker shall be applied. For the most part, these would be 3/4" A325 bolts. I've never heard of doing this before to structural bolts. It is for some modules that will be shipped by road and the theory is this will keep the bolts from vibrating loose. I would have thought the pretensioning would be sufficient to prevent that. Has anybody heard of doing this with structural bolts? If so, what type of Threadlocker would be used? I quick glance through the Loctite site doesn't suggest to me that it is intended to be used for this.
Bottom line is, should we push back on this requirement? Thanks.
