There are formulas I know of but I don't really use them. I googled and found out in one Hawaii University site where Reserve Capacity was approximated equal to CCA divided by 5. It further mentioned an approximation of AH from RC as AH = RC/2 + 16. E.g, a 1000 CCA is equivalent to RC = 1000/5 = 200 minutes. And the, the approximation of AH yields 200/2 + 16 = 116 ampere-hours.
(Please see that when you divide 116 AH by 5, we get 116/5 = 23.2 amps, which is very close to the defined rate of discharge in RC, i.e. the number of minutes the battery is delivering 25 amps until the terminal voltage drops to 10.5V.)
I know that once, battery manufactures rate batteries on a 5-hour validation test period. Later, manufactures used 1-hour basis for simplicity in marketing. Other ratings basis are the 8-hour, 10-hour and 20-hour.
Since CCA is the amount of current that can be drawn from batteries (at 0 - minus 18 deg F) for 30 seconds before the battery voltage drops to 10.5 volts (for 12-volt batteries), dividing the approximated RC by 2 (two, thirty seconds in one minute) and adding a little ampere-hours to account for the non-linearity will give AH values very near the rated AH. Other automotive battery manufacturers just approximate AH = RC x 0.6. (AH = 200 x 0.6 = 114, in the example).
Still, I don't use these formulas and just brought these up here for people to comment.
