Loading Analysis for base plate anchor bolt
If you are interested in the finer details of how their program works, and its calculation methodology, then you should probably call HILTI directly, and ask to speak with someone in their engineering department. No one knows their program as well as they will. Good luck in your inquiry,
Dave
Thaidavid
Profis assumes an infinitely rigid baseplate. The rest is simple geometry.
