Load sharing
Alms88
LK
In power system we power transfer is depend power angle between sending and receiving and and power angle adjusted by fuel control to synch gen .
How is load sharing done between to parrallel ups?
Or two solar inverters?
What principle they use to achieve this load sharing between inverter and between inverter and grid?
Inverter against grid is generally configured to go flat out until either the source falls away or the upper voltage limit is reached. Where export limited then its generally regulated via its own proprietary communications to a power meter of some description.
Same with parallel UPS I'd presume.
EDMS Australia
