Load on circular surface
  • Thread starter Thread starter hasan_t_almasri
  • Start date Start date
H
hasan_t_almasri
Guest
good evening.
i am trying to make a mechanical analysis for a lifting
lug,
05_091229_lifting_lug.JPG">
i am trying to apply load only to the upper half of the
circle, as it can be seen, its applied on all of it. i did
try to select the upper surface, no good :(
can this be done on pro e?? Please advice
You have to define a surface region on the part of the surface you want to select. then you can select this surface region.
