Studentforlife
Aerospace
Hello all,
I hope that all my fellow engineers are keeping well and safe. I was looking to get some advice from well-seasoned aircraft stress engineers on this forum.
I have recently come across a problem where I have loads defined for points 1,2 and combined moments at the location where the structure is fixed (points 3,4). I hope you can see the picture which I have tried to attach. I am now assessing Section a-a of the structure for stability and strength (by calculating section properties: moment of inertia, neutral axis etc.).
Would it be acceptable or conservative if I took a 60/40 load and moment split to obtain the loads at Section A-A? So the loading will look something like (Fx1+Fx2)x0.6, (Fy1+Fy2)*0.6 ... Mx x (0.6), My x(0.6) and so on?
Or
Do you suggest I resolve loads from Points 1 and Point 2 onto the neutral axis and obtain loads of Section a-a that way? Please keep in mind that the structure is fixed at points 3,4.
What are your thoughts? Looking forward to hearing from you.
Many Thanks
Sam
Or
Many Thanks
Sam
