Sundarzplanet:
Many of you guys seem to have no idea how important general proportions, load magnitudes, etc. are to an experienced engineering eye, assuming you would like real answers to your questions. An 8” brick corbel and a 100’ flag pole are both cantilevers, but they are treated much differently in their design. I don’t give a damn about A, B, C and D dimensions, I would like to know if the plate side “A” is about 100mm or 1000mm, and if the lifted load is 100lbs. or 100 tons, give or take a few pounds. Have you really drawn and studied a free body diagram (FBD) of that system? Do you really know the mech. props. of the insulation material, the thermal washers, the stl. pls. and the bolts, etc. What is the approx. tension in the bot. bolts during the lifting process? What is the compression force in the insul. mat’l. and how is it distributed? What do the thermal washers do to the rotation and strength of the system? If you are really an engineer, you should be able to start sorting these things out, and providing a sketch showing them. Otherwise, your sketch just shows you have two levels of people who have no idea what they are doing, on an important design problem, the engineer and their client. Where is the lifting load applied, and what prevents it from slipping of the end of the trunnion? Answer the questions above and come back here with a good FBD and you might generate some meaningful discussion, otherwise you are asking us to waste our time playing 20 questions with you.
Edit: By the way, I would not expect the 4 bolts to take the shear loading in that detail during the lifting process.
