Load customize Drafting templates NX12
TomMtz
147
Hi friends
Actually I have NX12 in my workstation, I want to load my customize drafting templates. whit another version, I changed the folder TEMPLATE and I copied the NX files in there, but is risky if I do that wrong.
Some one of you know how can I add my customize drafting templates easily and safe?
Thank for your comments
Tom
NX12 Windows 10 / Teamcenter 10
Friends
I forgot that I changed files with extension *.pax then I added the file name.
Thanks for your comments
Tom
The Template folder should be correctly defined in your env.dat file where the UGII_TEMPLATE_DIR variable points to correct path.
NX knows then where to look for the pax file and the templates. Your pax file needs to have the correct template names so NX knows which one to use when creating the different part types.
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
Building new PLM environment from Scratch using NX12 / TC11
NutAce
Thanks for your comments, I copied NX templates into the folder SIEMENS/NX12.0/DRAFTING/TEMPLATES and I changed the pax file with the new name of the customize templates.
But I am loking for a easily way to add customize templates from NX interface.
Tom
Ram K
Thanks for your comment, I will try this.
Tom
