I have a circuit design, where I am using a LM723 Voltage regulator to give me 12VDC. If I understand correctly the LM723 can supply 150ma without an external transistor. However, I have a load connected to it that is varriable, and the current draw will range from 40 to 50ma. I notice that when I reach 50ma. That I will see appromimately .3V drop in my 12V signal. Is this normal? or do I have a problem?
