cryotechnic
Chemical
- Dec 20, 2003
- 92
In our plant we are using a liquid ring pump to compres a gas from 80 mbar up to 4 bar.
The pump is a Siemens Elmo, single-stage double acting pump. The complete pump is build of 2 pumphouses, a low-pressure and high-pressure house.
The low-pressure pump has a diameter of 50cm and rotates with 750rpm.
The high-pressure pump has a diameter of 30cm and rotates with 1500rpm.
We understand that the diameter of the high-pressure pump needs to be smaller, the volume of the gas at the inlet of the highpressure pump is smaller due to the compression.
Our question is:
Why is it that the high-pressure pump turns faster??
When we reason it, higher RPM has the complete opposite function of the smaller diameter. In fact, the capacity of liquid ring pumps can be controlled with the RPM's.
Who can give us answers?
Thanks in advance,
Cryotechnic
Our question is:
Thanks in advance,
Cryotechnic
