Liquid Level in COMPRESS 6300
curlyjackme
61
I am having a problem with the new COMPRESS 6300 update increasing the thickness of vessels when a liquid level is added. For example I have a 5/8" thick vessel that 50' tan to tan and it increased the top head to 7" and the straight flange on the head to 18" and the top shell course to 4" when a 50' liquid level was added. Anybody else seeing this? Is there a way to correct it?
I can't reproduce it.
Check your specific gravity.
"Although this forum is monitored by Codeware it is not intended as a venue for technical support and should not be used as the primary means of technical support."
Tom Barsh
Codeware Technical Support
That was it I had a specific gravity of 20000. Thanks.
