kimdelfield:
OK, now that the rest of the story comes out I can clearly see what you are up against.
You want to use the condenser shell proper as the storage space for liquid hold up. For this, you are using a basic BKU TEMA type kettle configuration with the long shell side at the top - this resembles a vessel called a "guppy", with a lower belly. There is no subcooling taking place - just pure condensing (latent heat transfer).
I wouldn't do it this way; I believe this is an expensive way to obtain liquid hold up - but if that's the way you want to go, fine.
HTRI has nothing to say or to take into consideration with your configuration because the extra volume (not "area") has nothing whatsoever to do with the required heat transfer. What you have is a mechanical configuration and HTRI will calculate the correct heat transfer area for condensation as long as you furnish the proper baffles and/or internals to direct the vapor across the length of the tube bundle. I know how I would install the baffles and liquid drain off from each baffle pass but it near to impossible to draw a necessary sketch in this forum. The best I can do is a written explanation:
Install a horizontal rail system to allow tube bundle insertion and support. Around this rail system install metal plating to form a pseudo-shell wall around the underside of the bundle. This horizontal, rolled plate should have pipe downcomers allowing condensate to drain down into the belly of the guppy. The tube bundle would have the customary baffles to guide the vapors the length of the bundle. This would follow the accepted heat transfer algorithm used by HTRI and therefore allow for its calculation of required heat transfer area.
The way I would do it is to use conventional, less-expensire hardware like a TEMA BEU exchanger with a "double barrel" underneath it. This configuration is a horizontal tank (sometimes a large pipe with ellipsoidal heads on the end) supported under the exchanger and connected to it by dip pipes that lead the formed condensate down into the lower vessel - giving you the hold up required and allowing you to employ a low-cost U-tube design with liquid hold up.
I hope this helps out.
