Linking a set to a path
Eng1986a
Materials
Feb 2, 2010
I am currently undergoing a parametric analysis of my model where I am changing the lengths of certain geometries and seeing how this effects the moduli of the material.Currently, when I attempt to define a path from which to acquire the reaction forces, the nodes used change as the geometry changes for each model. Is there any way of linking the nodes in a Path to a previously defined node set.
Many Thanks
Create the node set based on the geometry not the nodes. Select and edge, face or point. Then when you remesh it will remap to the new nodes. I hope this helps.
Rob Stupplebeen
