Linked Bodies 1
aussiedesigner
17
Hi...
I've noticed in NX11 that when I Wave Link a body into another part file 'sometimes' I get a red box that appears in the 'Up to Date' column in Part Navigator.
I could understand this happening if I had made changes to the parent that the linked body is linked from, but it seems to happen even though I've made NO changes to the parent body that the link is referencing.
Unfortunately I can't access Wave Mode with the bundle we have so I can't freeze links. Not sure if that's the reason??
Any NX experts out there with suggestions would be greatly appreciated.
Thanks in advance.
Are there any Wavelinks, Interpart expressions, promotions in the source body?
If so, that might be the cause why NX shows the wave link to be out of date. It needs to know if the source is also up to date.
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
Building new PLM environment from Scratch using NX12 / TC11
Make sure everything is fully loaded, not just partially
Jerry J.
UGV5-NX11
