M
mhinkkanen
Guest
Possible.
Use one of following beams (or create your own):
<ul>[*]steel_beams_mm_mechanica[*]steel_beams_inch_mechanica[/list]
If you cant see these in your current EFX session, please add them to efx\parts\profiles\sel_list.txt and restart ProE.
After modelling your structure using these. Set simplified representation Mechanica and enter Mechanica. You should now be able to see beams which origin from EFX.
