Link lenghts from sketch to parameters
Wydaaadi
New member
Feb 9, 2014
1
Hello all,
I have a big problem, I try to link automatically using macros constraints (Lenght for exemple) from sketchers to parameters. I renamed about 300 constraints (lenghts) using specifically names and I need to link them to paramaters using the same names.
My parameters should have the constraints name and value. Is this possible using macros?
Thank's in advance.
Someting to start ..
Code:
Sub Link_Parameter_to_Dimension()
Dim oPart As Part
Set oPart = CATIA.ActiveDocument.Part
Dim D1Name As Object
Set D1Name = oPart.FindObjectByName("Diameter_1")
Dim D1 As RealParam
Set D1 = oPart.Parameters.CreateReal("D1", 2)
Dim oRelations As Relations
Set oRelations = oPart.Relations
Dim Param As Parameters
Set Param = oPart.Parameters.SubList(D1Name, True)
Dim oFormula As Formula
Set oFormula = oRelations.CreateFormula("", "", Param.Item(1), "(D1*1in )/2")
End Sub
an Approach... Be careful and test first on test file...
Code:
Sub Test()
Set Document = CATIA.ActiveDocument
Dim oPart As Part
Set oPart = Document.Part
Dim oBody As Body
Set oBody = oPart.Bodies.Item("PartBody")
Dim oSketch As Sketch
Set oSketch = oBody.Sketches.Item("Sketch.1")
Dim oConstraints As Constraints
Set oConstraints = oSketch.Constraints
For i = 1 To oConstraints.Count
Set Cst = oConstraints.Item(i)
If Cst.Type = catCstTypeDistance Then
Dim sName As String
sName = Cst.Name
  Dim Dime As Object
  Set Dime = Cst.Dimension
  Dim sParam As String
  sParam = Dime.Name
  Dim lValue As Double
  lValue = Dime.Value / 25.4
  Link_Parameter_to_Dimension sName, sParam, lValue
Else
End If
Next i
End Sub
Function Link_Parameter_to_Dimension(sName As String, sParam As String, lValue As Double)
Dim oPart As Part
Set D1Name = oPart.FindObjectByName(sName)
Dim D1 As RealParam
Set D1 = oPart.Parameters.CreateReal(sName, lValue)
Dim sBodyFormula As String
If Right(sParam, 6) = "Radius" Then
sBodyFormula = "(" & sName & "*1in)/2"
Else
sBodyFormula = "(" & sName & "*1in)"
End If
Set oFormula = oRelations.CreateFormula("", "", Param.Item(1), sBodyFormula)
End Function
