linear load in Pro/Mechanica Independent Mode
AnsysNewUser
Aerospace
Hi all,
I am working on a press fit problem, basically it is two circular rings fit togather. The bigger ring has a 5.0in external diameter, while the cross section is a 0.5 x 0.5 square. On the external surface of this ring, there is a circular load which is 15 lbs per inch, it should locate in the middle of the thickness. I created a circular curve geometry in Independent Mode, and applied the linear load on this circle, but when I use "Check Model", a message show "This curve has a load, but is not part of any element". Anybody can help on how to model this kind of load in such a case?
Thanks a lot!
Anny,
You may have a problem with associativity. The curve might not be associated with the element geometry. A way to fix this might be to re-create the curves by projecting them into the geometry of interest. This may help to enforce some associativity.
Best regards,
Matthew Ian Loew
"Luck is the residue of design."
Branch Rickey
Hi, MLoew,
Thank you so much for the quick reply. I will try that way.
Anny
