DYV1973
- Aug 9, 2004
- 75
We have connected a reed-switch (max 500 mA) to a digital input of a PLC (approx 7 mA). It is switched with a frequency of approx. 100 Hz by a circulating magnet. After 2 or 3 days, initially we measure that the frequency becomes less, before it does not work anymore. Under a microscope it looks like a grain of sand between the surfaces of the reed-switch.
* what causes this effect on the reed-switch, as the current is not too high? Can higher temperatures (130°C) cause these kind of problems?
On the input side of the PLC there is a varistor (between input and ground); is it possible that a varistor acts like a capacitor (so it causes a high current-peak), although the voltage (24V) never exceeds the specified level of the varistor (30V).
Thanks,
DYV
Thanks,
DYV
