Hi everyone;
I want to keep the supply to an IC within 8-20 volts interval while the possible DC supply occurs within 10-30 volts from a battery. I used a 2.4 volts zener diode in series with the Vcc pin of IC to achieve the lower limit 8V theoretically but unable to limit the supply to IC to 20 volts when the DC input exceeds over that value.
Any considerations without using a regulator is needed.
Thanks.
Thanks.
