XR250
- Jan 30, 2013
- 5,987
I have an interior metal stud wall supporting floor joists. The contractor wants the joists 24" o.c. and the studs 16" O.C. As such, my top track has to act as a beam spanning 16" The positive moment capacity of the track is approx. 4 in-k (legs in tension) while the negative moment capacity is only 1.5 in-k (legs in compression). In the past , I have always designed for the lesser negative moment capacity. Is the situation self limiting, however? If it begins to fail in negative moment, won't the positive moment capacity take over (i.e. acting as a series of simple span beams)?
