Lift shear wall and column has to be joint?
akgtm
MD
Does lift shear walls needs to be joined at column?
More information on your question & situation is required.
Jim
Can we construct shear wall for lift above orginal foundation as the original footing is more deeper than required lift pit. So the mat footing for shear wall raises above the original building foundation. I plan to attach the shear wall into orginal building column but will have different footing. I hope you understand 🙂
