LH thread designation 1
Dave K
Automotive
Aug 27, 2003
515
Other than ASME B1.1-2003, are there any specs that denote the "LH" at the end of a thread callout, to specify it is a left handed thread?
-Dave
NX 9, Teamcenter 10
Thanks. I'm building a case, to show an enhancement is needed in some software.
-Dave
NX 9, Teamcenter 10
Dealing with NX, just modify the thread callout tables for the LH designation, or build a separate table for LH threads. The thread tables are generic and work for LH or RH threads. The software has no method to determine if it is RH or LH, that is usually added after the hole has been modeled into the part with appended text.
Ben Loosli
Which is what I don't understand, you have the option to tell NX if the thread is right or left handed, yet it doesn't use that information, if the thread is symbolic. I don't like relying on the user, to remember to append that text.
-Dave
NX 9, Teamcenter 10
Not a worry. When the shop puts in a RH tap and the CNC drives it as a LH tap, the difference will become quite obvious.
Seriously - NX doesn't drive the note from a pre-determined table of acceptable threads?
I posed the question here, not for help with NX, but to gather information on specs, so that I can submit them to Siemens, in support of my "issue".
-Dave
NX 9, Teamcenter 10
I would suggest asking in the NX forum. John Baker has great knowledge of NX and is an active participant in that forum. I think he wrote most of the original tables used for the tap-drill information.
3Dave, yes NX does use tables to generate the notes for tapped holes. I used to modify them to use the tap drill that our shop used instead of what Siemens thought they should be using. Did the same for the Pro/E tables.
Ben Loosli
Thanks Ben. John is already aware of this issue, and submitted his own PR on it too.
-Dave
NX 9, Teamcenter 10
