Lever DRF callout
Attached is a door lever we used popularly, the shank is assigned as datum B, there is a hole drilled and a square hole broached on the center. I am not making a test on you and want you to choose the right answer, but it’s a real drawing callouts from our customer designer, different company designer will select different DRF, I am confused on these DRFs callout
A.For the central hole position callout
* A drawing has three datum features is pretty common, shall we completely control the part (constrain all six degrees of freedom) for a position callout?
* What is the meaning and differences between them if they are legitimate?
B.For the central square hole position callout
* The diameter symbol is not allowed here and it have been discussed many times on ENG-TIPS forums, but as a manufacturer they will request more tolerance as the cylindrical tolerance zone has, any other GD&T tolerance can meet this target?
* Same question again, shall we completely control the part (constrain all six degrees of freedom) for a position callout? Is the callout correct on circle #6?
* One of the print without datum A, only datum B and C shows on the print, is it legal on the position callout |POS|.010|B|C| as shown on circle #7?
C.For the central square hole perpendicularity callout
* Is Ø allowed on perpendicularity callout here?
* I can understand the meaning of |Perpen|.004|A|B|, but what’s the meaning of |Perpen|.004|B|C|?
D.For the central slot position callout
* Does this position callout can control the perpendicularity with respect to datum C?
Thanks for all comments and inputs
SeasonLee
SeasonLee
