I am trying to size a LCV from a separator, The separator pressure is 75 psig and the downstream of LCV goes to a vessel where pressure is maintained by blanketing at 5 psig.
What DP should be considered for the control valve? should it be 75 - 5 = 70 psig or
for the downstream of LCV should we consider pr. drop across piping also??
Since LCV only maintain level, is the pressure downstream of LCV defined by system pressures?
If the pressure downstream of LCV suddenly rises to more than 5 psig and differential pressure acorss lcv reduces, what will happen in that case? will flow reduce and ultimately level will not be maintain?
