Length between Expansion Joints
OneStepBehind
14
I have a general question. I have a building that has a 6'-0" high above finish floor 8" thick concrete wall around the entire perimeter. The wall varies from 3'-0" to 6'-0" below finish floor for frost protection and height at the loading dock. So the wall varies to between 9'-0" to 12'-0" in total height. My question is how often should I place expansion joints in this wall?
thanks.
Depends on the overall size of the wall.
Is it reinforced or plain concrete?
Expansion joints or control joints? I would say expansion joints every 200', control joints every 12-16'. Anyone disagree?
It is an addition and the front and rear walls are 150'-0" long while the side wall is 300'-0" long. It is reinforced. I am talking expansion joints. I have the control joints located at no more than 1.5 times the wall height and closer to 1.0.
I see no reason for an expansion joint in a 300' long concrete wall, unless there is an expansion joint in the building. Concrete shrinks so contraction is the issue.
rowing,
That is a good link. I have always used technical report 65 for placing thermal expansion joints. However, I have never made the interpretation with regards to option #3. I have always tried to limit my lengths to around 400-500 feet (and I thought that was pushing it). However, according to option #3 I could go as much as 800 feet as long as my bracing is in a side.... I'm not entirely sure I am comfortable with that.
Thanks for all your help. All the replies were very helpful. I enjoyed receiving your good advice. I guess I was a little too conservative. Kinda like the old engineer I knew that wore a belt and suspenders.
