Yes, I have in my hand a copy of the API 650, ed. 2007. The Clause 7.3.4 reads:
"After fabrication is completed but before the tank is filled with test water, the reinforcing plates shall be tested by the Manufacturer by applying up to 100 kPa (15 lbf/in.2) gauge pneumatic pressure between the tank shell and the reinforcement plate on each opening using the telltale hole specified in 5.7.5.1. While each space is subjected to such pressure, a soap film, linseed oil, or
another material suitable for the detection of leaks shall be applied to all attachment welding around the reinforcement, both inside and outside the tank."
This is a standard procedure applied for pressure vessels ditto.
Cheers,
gr2vessels
