LDD 2005 pipe routine chaos
SouthernDrafter
A coworker of mine is having a problem with the PIPES routine in LDD. When she goes to Manning Circluar her machine displays the following warning- BUFFER OVERRUN DETECTED..then her CAD crashes.
Anyone know what the problem could be?
Thanks in advance!
I am not familiar with the program, but it sounds like it is caught in a loop or is running out of memory space while computing something.
"The fear of the Lord is the beginning of wisdom"
Do you mean the 'Hydrology' menu, not 'Pipes'? The only Mannings Circular option I can find is under Hydrology.
Yes, that is correct...my bad.
However, even with just the regular pipe routine, CAD will often freeze up and crash. It seems to be a problem with everyone, so I assume it's a bug in the system. I was hoping that anyone who has had the same problem may have figured out a way to correct it, or perhaps something that could be done to prevent it from happening.
