Hello Everyone,
I have one question as to the applicability/feasibility of lateral forces (?) on the bottom-running monorails systems - travelling along the bottom flange of the supporting beam.
Understandably, in case of top running crane girders lateral surge force is mainly derivative of the thrust from sudden application of brakes attached with crab(trolley) motor... estimated as 20% of the combined weight of the lifted load and trolley.
However, my feeling suggests that in the case of bottom running system the load to be lifted is constrained to move along the bottom flange of the supporting beam, since for an under-hung and under-running system the end trucks operate on lower flanges of the runway beams.
Since there is no movement of the lifted weight in the lateral direction which could result in zero lateral force in the design of under-hung and under-running monorails systems.
Does this sound legitimate to anyone in this forum?
Please let me have your opinion.
Thanks & Regards.
Thanks & Regards.
