Stress Engg
Petroleum
I am performing stress analysis of above ground surface laid flowline with buried portion only at crossings (road, existing facilities etc.). the MOC is API 5L Gr-B and the design code we are using is ASME B31.8. In one of the section of the flowline, we are having an IP (change in direction) angle 12° and with crossings at each ends at a distance of 70m and 20m on each side of bend. The flowline temperature is 120°C and pressure is 100 bar. However, the lateral deflection at IP point (only at far point, mid point and near point of bend) suddenly shoots up to approx. 500mm. Beyond this 3 nodes, the displacement is in the range of 200mm only. I am not able to understand why this much high lateral deflection is happening at bend even though the expansion length is only 90m?
