sandcd
- Jul 8, 2010
- 2
I'm trying to analyse a fairly simple flat plate under surface pressure (out of plane loading) using large deflexion theory. I have no problem down to a plate thickness of 2mm but as soon as I drop below about 1.6mm I get an error message saying that the iteration will not converge. I haven't given any value of yield strength, so the plate can't be actually failing. Now the maths shouln't care what thickness I use so I presume it is some sort of limit in a default setting. I have had a go at changing these but haven't got anywhere.
Has anyone got any ideas why I am having this trouble.
