For a large casting that must be weld repaired (4130,CE~.695)I am wondering if I should exercise some cautions as we will have several interuptions before we can send it out to final PWHT.
A large steam valve casting consists of a couple of adjent chambers with a very heavy wall (~3" thk) in between and the outside wall thickness is also ~3" thk. Some of the cracks to be weld repaired may require excavation up to 3/4" deep and are in/near the corners of the chambers. We will preheat the entire body upto 400 deg F before any welding takes place. Before all repairs are finished, we will have to stop and cool to room temps several times for inspections as well as manual repositioning to reach other crack repair locations.
In between each weld cycle would it be advisable to cool this casting down to just below the martensite finish temperature and hold until temperature equilibrium is reached, then increase temp to accomplish local stress relieving temperature and THEN cool to room temperauture?
This was suggested to me by a young University professor who admits not having more than academic welding experience. But it makses sense. The method will be cumbersome to me - Is it all necessary in your point of view? Comments/thoughts welcomed.
By the way, temper beading was discussed and rejected by our engineer folks.
