I was taught to avoid L shaped structures..... meaning they need to have an expansion joint near the vertex to avoid odd seismic behavior.
Last week I had a client send me over a new building.
Code = IBC 2015
Location = North East USA
Single Story (approximately 29' to top of steel)
Material = Steel framed with metal mixture of CMU and metal studs
After a bit of work I was able to get a ton of bracing into the building (see attached).... maybe too much and I may be able to take some out upon further analysis. The issue I have with splitting the building is that I will have to add even more bracing into the building.
With this much bracing, do you really think I need to add an expansion joint to it (considering I have the vertex braced pretty well)? What do other thing of this issue?
Code = IBC 2015
