BadgerPE
- Jan 27, 2010
- 500
Hey all,
Attached is a sketch of an arbitrary retaining wall. For the example a #5 dowel was assumed to be used and I am using ACI 318-08. My question is, because maximum tension occurs at the stem/footing interface, does ldh need to fall completely within the footing? Or is it acceptable for ldh to extend up into the stem? I would need about an 18" thick footing for this scenario which doesn't seem too bad, but if #8 dowels were used a 26" thick footing would be needed.
Thanks in advance!
Thanks in advance!
