EE's:
I'm an agricultural engineer that is working on the sizing of generators for center pivots (motor starting applications). I'm a little confused about kW vs. kVA and the power factor. Is the power factor value something that is associated with the motors, the generator, or both? Should the kVA value or the kW value be used to size the driver for the generator? I'm familiar with the 3-phase equations such as:
kVA = V*1.73*I/1000 and kW = kVA * PF
I'm just unsure when to use kW or when to use kVA, etc.
Also, is there a general rule of thumb about how efficient generators are in converting the mechanical energy into electrical energy? I would imagine this varies by the degree of load on the generator.
Thanks for any help.
Jeremiah
Jeremiah
