I would like to post a doc from Moldflow HELP.
The Weld lines result is generated at the end of a filling analysis. This analysis shows where weld lines are likely to occur on your model along with the angle at which the flow fronts converge to form the weld line. Weld lines occur where two or more flow fronts converge. The presence of weld lines may indicate a structural weakness and/or a surface blemish. For a full list of flow analysis results
Weld lines can cause structural problems, and they can also make the part visually unacceptable. However, some weld lines are unavoidable, so you need to look at the processing conditions and the weld line position to decide if the weld lines will be of a high quality.
Weld line strength is influenced by the temperature at which the weld line is formed and the pressure exerted on the weld while the material is within it's recommended processing temperature range.
Structural problems - The part may be more likely to fracture or deform at a weld line, especially if the weld line is of a low quality. This weakness will be more of a problem in areas of the part which will be subject to stress.
Visual defects - A weld line can cause a line, notch or color change on the surface of the part. If the weld line is positioned on a non-critical part surface (for example, the bottom of the part), this may not be a problem.
Remedy
To move weld lines, change the fill pattern to make the flow fronts meet at a different place:
Increase the wall thickness.
Decrease the part thickness ratio.
Adjust the gate position and dimension.
To improve the quality of weld lines:
Increase the diameters of gates and runners.
Move injection locations to make weld lines form closer to the gates.
Move injection locations to make flow front meet more obliquely.
Increase the melt temperature, injection speed, or injection pressure or packing pressure.
Place a vent in the area of the weld line. This will remove air traps, which should further weaken the weld line.
