killing harmonics
killabyte
67
i want to make a filter to clean my ac line, but wich harmonics are the principal to deal with? i work in audio environment and usually i have to connect very low loads (very impositive) between 38 and 110 Hz in the mains and beats of 0.7 - 0.8 millisecond, high power peaks.
i dont know, first to kill third and 5th or to make a LPF at 70 Hz -3 dB? needing some advice.
thankx.
killa
Suggestion: The low pass filter would not filter out subharmonics and interharmonics. The most accurate filtering would be a notch filter for the specific frequency, and in your case a bandpass filter that would pass frequencies from 38Hz to 110Hz.
See the engineering and design of filters in:
Donald G. Fink, H. Wayne Beaty "Standard Handbook for Electrical Engineers," 13th Edition, McGraw-Hill, Inc., 1993, page 2-57
Section: Filters by Harry W. Hale and Edwin C. Jones Jr.
There are software packages that design the passive filters effectively.
What's your budget? There are some excellent active filters which flatten all harmonics up to a few kHz, but these tend to be three-phase. I think a US company called Powersmiths was developing a single-phase unit a few years ago, but I don't know if it ever went into production.
