Kids trapped in a cave 25
3DDave
Aerospace
May 23, 2013
11,275
Not a result of engineering, but one that might benefit from it.
The kids soccer team is trapped in a cave. From the graphic on the news it seems there are several pools that have sealed off the exit path. The children are supposed to be unable to swim, though I don't know that that is a special limitation. More concerning is that using scuba equipment might be too complicated for them; not only are they not familiar with it, the water they will move through is so murky that they would essentially be blind, deaf, and unable to communicate so that even guides would be unable to help them escape.
There is no immediate problem for them; they are now supplied with food and water and medical care. They have been without food for a week and will take a while to recover from that.
However, there is no known time at which the water will recede from the cave. I expect that there is insufficient pumping capacity to offset the rate at which it can be replenished. On the news they estimated weeks to months before the cave might dry enough.
Since they are in the cave, the passage was certainly large enough to get in and so there should still be enough room to get out. In particular full-sized adults have made the journey.
A thought occurs to me that it should be possible to pull corrugated tubes through each of the pools and then pump those out. If the ends are above water, there should be no replenishment beyond minor leaks for the pumps to offset. Using these the children should be able to crawl out, and will have light and audible communications to guide them.
The water is apparently only 16 feet deep at most, so the pressure can't exceed 8 psi. Anchorage will be required to keep it from shortening axially, but that should be a few hundred pounds to be useful.
I would estimate that a 24 inch diameter would be enough. I'm thinking of construction as is used for ventilating manholes, possibly with stronger wire.
If the tube obstructs the path for the adults, then they can wait the few days while the tubes are placed, the children escape, and then the tubes can be retrieved. If they are anchored against the cave roof by buoyant forces, they can be flooded again and then pulled back out.
Does this seem like a feasible way out?
I applaud Musk for his attempt to help.
However his attack on the diver was several orders of magnitude in the other direction.
This is a real David and Goliath drama from several perspectives.
Contrast Unsworth's comment with Musk's repeated false accusations and repeated character assassination.
Contrast Musk's power and influence with Unsworth's power and influence.
Contrast Musk's wealth with Unsworth's wealth or lack thereof.
If Unsworth gets vindication, expenses, an apology and one dollar, so be it.
However, if the judge awards punitive damages to be donated to a charity of Unsworth's choice, how much is punishment for a man with 20 billions.
How about a billion or two?
That would be both meaningfully punitive to Musk, end exemplary to rich bullies everywhere.
Bill
"Why not the best?"
Jimmy Carter
That is an amazing story.
faq731-376
The Australian 4 Corners documentary linked by Artisi on 31 July 18 is probably still the best explanation of the rescue I have seen. The sedation and restraint of the boys is well explained there.
Those were some terrifying decisions to be made. Striking that the anesthesiologist asked for diplomatic immunity since they thought they might lose so many in the rescue.
On one BBC programme, I guess it was the UK lead diver's comments was something like, I don't like our chances of a successful outcome, that says it all.
You seem to have missed the update to the article, which was the notice that the New England Journal of Medicine correspondence about the medical and protocol used for the transport to the hospital was published yesterday
TTFN (ta ta for now)
No, I didn't miss that. But all the other information in the article, including the sedation with ketamine, has been reported months ago, and is referenced in posts above.
Maybe so, but it reads like a new article to me. The reference to the event happening "last year", for one thing. If it is an update, they should have at least footnoted the original date of publication. Oh well, serves me right for reading something on CNN.
Thank you, hokie66, for sharing with us the excellent article from CNN's Health section! It had not been previously reported here that ketamine was used to sedate the children. The additional information the piece provided about ketamine was interesting; particularly as it related to the the appropriateness of its use given the hypothermic conditions the children were exposed to. The link to the source material is an appreciated simple element of their reporting that lesser news organizations often fail to include in their stories.
I assume your comments about CNN were sarcasm, Spartan5, but no matter.
The use of ketamine, along with Xanax and atropine, were previously reported on in the Daily Mail article linked by Artisi on 15 Jan 19, 0805. The documentary by the Australian ABC which he linked on 31 July 18 0209, reported on the anesthesia, but maybe not the drugs used. But this information has been widely reported since then in the Australian press, and Doctors Richard Harris and Craig Challen were honoured as Australians of the Year for their part in the rescue.
