rb1957 (and beej67),
1) I’m not saying that they do not tune models. The assertion being made is that parameterization and other such “control knobs” are tuned in order to
match historical temperature records directly (i.e. chasing the noise).
That is incorrect. The “knobs” are tuned to create a better representation of their specific aspects of the climate system. These adjustments can only be made in the range established by observations or peer-reviewed study. Once that is achieved, they run the GCM to see how they compare to observed temperature trends. If there are discrepancies, they aim to resolve them by reviewing how the subsystems or the interaction between subsystems are represented. Again, this is done to better represent those aspects, with the indirect result being a more accurate representation of historical temperature trends. They do not blindly tune these parameters, such that they behave in a way outside of observed, experimental or theoretical expectations, just to match the GCM to historical temperature trends.
This is made clear in the paper beej67 referenced:
Mauritsen et al 2012 said:
Climate model tuning has developed well beyond just controlling global mean temperature drift
The MPI-ESM was not tuned to better fit the 20th Century. In fact, we only had the capability to run the full 20th Century simulation according to the CMIP5-protocol after the point in time when the model was frozen.
The impacts of the alternative tunings presented were smaller than we thought they would be in advance of this study, which in many ways is reassuring. We must emphasize that our paper presents only a small glimpse at the actual development and evaluation involved in preparing a comprehensive coupled climate model
I don’t disagree with the Mauritsen et al paper. It outlines the modeling process and highlights some accurate concerns. My contention is with the unfair and, at times, untrue stretching of its conclusions, which are directly disproven by quotes from the paper itself. Curry actually did not make this mistake (at least not directly). She said very little about the paper besides calibration is poorly documented. She left it up to her readers to misrepresent the paper, which they did in spades.
For more information and to avoid the one-study syndrome, I recommend reading
IPCC AR5, specifically box 9.1 on the subject.
2) There was a dip after the medieval warm period, yes. The rate of both the warming during the Medieval Warm Period and cooling of the LIA were much lower than the rate of change seen recently. Furthermore, the extent of warming during the Medieval Warm Period and subsequent cooling of the LIA are not as great as some “skeptics” might believe it is. Much of the “drastic” warming in the MWP comes from only using temperatures from one region and saying it was global (very similar to the faulty argument made about Antarctic temperatures during the last glacial-interglacial period).
3) One-study syndrome. One-study, that has been shown to have serious holes in it by various other studies, shows that Mann ’98 was a “fabrication”. Meanwhile, numerous studies have validated Mann ’98. To avoid this trite topic, I’ll just say, fine throw out Mann ’98 from this discussion. How does this help with beej67’s point (which is what again? He’s hopped between arguments, selectively choosing which rebuttal to address and which to ignore, that I have lost track of his core argument).
4) Addressed in 2. Yes, there was some warming in the Medieval Warm Period. However, it was nowhere near the extent of the warming in the last glacial-interglacial period or recently, for that matter. The rate of warming is an even worse comparison between the MWP and today. So, what’s your point? Does it relate to beej67’s?
beej67, what? I’m saying that there was a major shift in climate about 18,000 years ago and then stabilized around 10,000 years ago. There have been relatively minor variations since then (MWP and LIA discussed above). However, now we are in another shift in climate, this time it appears to be driven by anthropogenic actions. The rate of this change is unlike the last glacial-interglacial period.
But, as stated above, you’ve bounced around from point to point, failing to address half of what I’ve said. I’m at the point that I don’t know what your even arguing for (and I believe you don’t either). Here’s a rundown of your past points:
1)
Anthropogenic actions aside from CO2 emissions are the cause of the warming – I’ve referenced a bunch of articles that look at the forcings from various anthropogenic sources and CO2 is the greatest forcing. You haven’t responded to this or provided anything to support your claim.
2)
CO2 emission restrictions will not slow temperature rise – Completely off topic from point 1. I discussed equilibrium climate sensitivity. You didn’t really response to this but made the false claim described below.
3)
CO2 emission restrictions won’t work because we have to completely eliminate CO2 emissions to keep concentrations at a safe level – Completely off topic from point 1. Regardless, I (and others) have demonstrated that this is false. It’s really silly logic. You haven’t responded to this or provided anything to support your claim.
4)
Models are tuned to match historical temperatures – Completely off topic from point 1 and 3. Regardless, I have demonstrated that this is false (twice now). You actually did offer something to support your claim but the problem is, it doesn’t really support your claim.
5)
It was warming before the industrial revolution! – Completely off topic from point 1, 2 , 3 and 4. Regardless, I have demonstrated that this is false. You need to provide something to support this claim.
6)
Some random article from GWPF – Nothing to do with anything else really. Regardless, I demonstrated that the author of the main paper GWPF used in their argument said that their conclusion was wrong. Your rebuttal was to include a quote which actual validated my point.
Find a topic, define why and how it challenges the CO2 theory, support it with references and then stick with it. This jumping from topic to topic is such a tiresome game by “skeptics”. I’ve actually taken the time to address each individual concern, perhaps encouraging this silliness, and then you or someone else completely changes the topic. It’s gish gallop, pure and simple.
