I need to use the CERIG command to simulate a diaphgram behaviour in a building, the problem is the I've built my modelling using keypoints and assign properties to the structures.
The CERIG command define a plane where all the NODES have the same displacement of the defined master node. But I want to define master nodes and slave nodes by keypoints, because it is much easier for me. So, is there an easy way?
Is there an easy way to export a list of nodes with a sort of "dictionary" that tell me which node number is related to a particular keypoint number? Because if I have the relationship between keypoints and nodes I can easily generate a command file where I put the Node number instead of the Keypoint number.
Thanks,
Luca
Thanks,
Luca
