Keep nodal selection order in FEMAP
stressengineer26
Aerospace
I want to keep the selection order of nodes when I extract results from FEMAP. currently, when I extract results to data table, FEMAP automatically sorts my nodes in ascending order and i do not want that.
anyone knows how I can keep my nodal selection order?
thanks,
isn't there a choice somewhere "use selection order"
'use selection order' choice is available when you want to "list" nodes. but I didnt see any such option while extracting results to data table.
stressebookllc, good idea but the only thing is I have don't have a few nodes. I have like 20 nodes or so which becomes very cumbersome. but thanks for your suggestion!
how about putting the nodes in a group, and using the f06 file to print the results ?
if you want only a few sets of nodes, how about renumbering the nodes (to be sequential) ?
yes, i'm olde school ...
not sure how to use f06 file to print results :(
renumbering is the easiest approach of all. Thanks
"not sure how to use f06 file to print results :(" ... under print options (in the analysis setup, yes?). i think it's the same screen for entering the constraint case and the load case. down near the bottom of the page "print options", elect "3, print and post-process", i think.
