Journal to select only sheet bodies?
CNSZU
318
I'm using this to select only solid bodies:
Dim selectionfilter(0) As MaskTriple
selectionfilter(0).Type = NXOpen.UF.UFConstants.UF_solid_type
selectionfilter(0).SolidBodySubtype = NXOpen.UF.UFConstants.UF_UI_SEL_FEATURE_SOLID_BODY
but how should I select only sheet bodies?
NX10.0 Win8.1 64bit i7-3770K 16GB Quadro2000
Code:
selectionfilter(0).SolidBodySubtype = NXOpen.UF.UFConstants.[highlight #FCE94F]UF_UI_SEL_FEATURE_SHEET_BODY[/highlight]
www.nxjournaling.com
Thank you!
(feeling dumb)
