Journal to select endpoints
zyxcba
I'd like to create a journal in NX 7.5 that makes several arcs and then connects their endpoints to create a profile. I wrote a journal to create the arcs (simplified version below, the final version will have hundreds) but since I don't know exact coordinates of the arc endpoints, I haven't figured out a way to create lines connecting the arcs. Is there a way to designate the endpoint of an arc in a journal without the user selecting it? Thanks!
Option Strict Off
Imports System
Imports NXOpen
Module NXJournal
Sub Main
Dim theSession As Session = Session.GetSession()
Dim workPart As Part = theSession.Parts.Work
Dim displayPart As Part = theSession.Parts.Display
Dim angleStart As Double
angleStart = 0
Dim ptCenter As New Point3d(0, 0, 0)
Dim arcStep As Double
arcStep = 0.4
Do
DrawArc(angleStart, angleStart + arcStep, 4, ptCenter)
angleStart = angleStart + arcStep + 0.2
DrawArc(angleStart, angleStart + arcStep, 3, ptCenter)
arcStep = arcStep + 0.1
Loop Until angleStart > Math.pi
End Sub
Sub DrawArc(ByVal arcStart As Double, ByVal arcEnd As Double, ByVal radius As Double, ByVal ptCenter As Point3d)
Dim nxMatrix1 As NXMatrix = CType(workPart.NxMatrices.FindObject("WCS"),NXMatrix)
Dim arc1 As Arc
arc1 = workPart.Curves.CreateArc(ptCenter, nxMatrix1, radius, arcStart, arcEnd)
End Sub
End Module
That's amazing, thank you so much!
