Journal to move assembly components beginning with a certain letter to a layer
ArcMcE
4
I've been trying to create a journal to send all components in an assembly which begin with a certain letter (in this case 'F') to a layer. I've tried loads of bits of code from other similar threads online, but cant get any of them to work. I think the problem might be that I am using the wrong object type (if that's the right term? I mean such as 'as component' or 'as ComponentAssembly'). I was trying to add the components that begin with F to an array, which i would then process to move the layer.
The code below is one not-working version of what i have managed to do so far. I tried using parts of the code which is created when i recorded a journal of moving a component to a layer, but that didn't work either. The commented out section of the code is what i used to see if the code is at least finding any components beginning with the letter F, and it seems to be able to do that - Its just the moving to a layer part I'm stuck with.
I hope someone will be able to point me in the right direction.
Thanks in advance.
Code:
Option Strict Off
Imports System
Imports System.Collections
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.Utilities
Imports NXOpen.Assemblies
Imports NXOpenUI
Module NXJournal
    Sub Main()
        Dim theSession As NXOpen.Session = NXOpen.Session.GetSession()
        Dim workPart As NXOpen.Part = theSession.Parts.Work
        Dim dispPart As NXOpen.Part = theSession.Parts.Display
        Dim lw As ListingWindow = theSession.ListingWindow
        lw.SelectDevice(ListingWindow.DeviceType.Window, "")
        lw.Open()
        Try
            Dim c As ComponentAssembly = dispPart.ComponentAssembly
            Dim Fixings As ArrayList = New ArrayList
            Dim Part(0) As NXOpen.DisplayableObject
            If Not IsNothing(c.RootComponent) Then
                ReportComponentChildren(c.RootComponent, Fixings, Part)
                'Dim fixing As String
                'For Each fixing In fixings
                '    lw.writeline(fixing)
                'Next
            Else
                lw.WriteLine("Part has no components")
            End If
        Catch e As Exception
            theSession.ListingWindow.WriteLine("Failed: " & e.ToString)
        End Try
    End Sub
    Sub reportComponentChildren(ByVal comp As Component, ByRef Fixings As arraylist, ByVal Part() As DisplayableObject)
        For Each child As component In comp.GetChildren()
            If child.DisplayName.ToUpper Like "F*" Then
                part(0) = child
                workPart.Layers.MoveDisplayableObjects(199, part)
                'Fixings.Add(child.DisplayName.ToUpper)
            End If
            reportComponentChildren(child, Fixings, part)
        Next
    End Sub
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        Return Session.LibraryUnloadOption.Immediately
    End Function
End Module
I managed to fix this myself - It's messy but it does the job! I hadn't passed the 'workpart' to the 'reportComponentChildren' sub.
If anyone has any general tips for cleaning up this code, I'd be happy to hear them.
Code:
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpenUI
Module NXJournal
    Sub Main()
        lw.Open()
        Try
                ReportComponentChildren(c.RootComponent, Fixings, Part, workpart)
                'Next
            Else
            End If
        End Try
    End Sub
    Sub reportComponentChildren(ByVal comp As Component, ByRef Fixings As arraylist, ByVal Part() As DisplayableObject, ByVal workpart As NXOpen.part)
                part(0) = child
            End If
            reportComponentChildren(child, Fixings, part, workpart)
        Next
    End Sub
    End Function
End Module
