Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Option Strict Off
Imports System
Imports System.Collections.Generic
Imports NXOpen
Imports NXOpen.UF
Module Module1
Dim theSession As Session = Session.GetSession()
Dim theUfSession As UFSession = UFSession.GetUFSession()
Dim theUI As UI = UI.GetUI()
Dim lw As ListingWindow = theSession.ListingWindow
Sub Main()
Dim markId1 As Session.UndoMarkId
markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Face attributes")
lw.Open()
Dim selobj As NXObject
Dim type As Integer
Dim subtype As Integer
Dim theFaces As New List(Of Face)
Dim numsel As Integer = theUI.SelectionManager.GetNumSelectedObjects()
'process the preselected Faces
If numsel > 0 Then
For inx As Integer = 0 To numsel - 1
selobj = theUI.SelectionManager.GetSelectedTaggedObject(inx)
theUfSession.Obj.AskTypeAndSubtype(selobj.Tag, type, subtype)
If type = UFConstants.UF_solid_type Then
theFaces.Add(selobj)
End If
Next
Else
'prompt to select Faces
If SelectFaces("Select Faces to reset attributes", theFaces) = Selection.Response.Cancel Then
Return
End If
End If
For Each temp As Face In theFaces
DeleteAllAttributes(temp)
' AddFaceAttribute(temp, "TOOL_CLASS", "ALT STD")
AddFaceAttribute(temp, "HOLE_SIZE", "DIA 9")
' AddFaceAttribute(temp, "PURCH_OPTION", "P")
' AddFaceAttribute(temp, "DB_PART_NAME", "NC BLANK")
Next
lw.Close()
End Sub
Function SelectFaces(ByVal prompt As String, ByRef selFace As List(Of Face)) As Selection.Response
Dim title As String = "Select Faces"
Dim includeFeatures As Boolean = False
Dim keepHighlighted As Boolean = False
Dim selAction As Selection.SelectionAction = Selection.SelectionAction.ClearAndEnableSpecific
Dim scope As Selection.SelectionScope = Selection.SelectionScope.WorkPart
Dim selectionMask_array(0) As Selection.MaskTriple
Dim selObj() As TaggedObject
With selectionMask_array(0)
.Type = UFConstants.UF_solid_type
.Subtype = 0
.SolidBodySubtype = UFConstants.UF_UI_SEL_FEATURE_CYLINDRICAL_FACE
End With
Dim resp As Selection.Response = theUI.SelectionManager.SelectTaggedObjects(prompt,
title, scope, selAction,
includeFeatures, keepHighlighted, selectionMask_array, selObj)
If resp = Selection.Response.Ok Then
For Each temp As TaggedObject In selObj
selFace.Add(temp)
Next
Return Selection.Response.Ok
Else
Return Selection.Response.Cancel
End If
End Function
Sub AddFaceAttribute(ByVal theFace As Face, ByVal attTitle As String, ByVal attValue As String)
Dim markId4 As Session.UndoMarkId
markId4 = theSession.SetUndoMark(Session.MarkVisibility.Invisible, "add Face attribute")
Dim attributePropertiesBuilder1 As AttributePropertiesBuilder
attributePropertiesBuilder1 = theSession.AttributeManager.CreateAttributePropertiesBuilder(theSession.Parts.Work, {theFace}, AttributePropertiesBuilder.OperationType.None)
attributePropertiesBuilder1.IsArray = False
attributePropertiesBuilder1.DataType = AttributePropertiesBaseBuilder.DataTypeOptions.String
attributePropertiesBuilder1.Title = attTitle
attributePropertiesBuilder1.StringValue = attValue
Dim nXObject1 As NXObject
nXObject1 = attributePropertiesBuilder1.Commit()
Dim id1 As Session.UndoMarkId
id1 = theSession.GetNewestUndoMark(Session.MarkVisibility.Visible)
Dim nErrs1 As Integer
nErrs1 = theSession.UpdateManager.DoUpdate(id1)
attributePropertiesBuilder1.Destroy()
End Sub
Sub DeleteAllAttributes(ByVal theObject As NXObject)
Dim attributeInfo() As NXObject.AttributeInformation = theObject.GetUserAttributes
For Each temp As NXObject.AttributeInformation In attributeInfo
theObject.DeleteUserAttributes(temp.Type, Update.Option.Now)
Next
End Sub
Public Function GetUnloadOption(ByVal dummy As String) As Integer
'Unloads the image immediately after execution within NX
GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately
End Function
End Module
.SolidBodySubtype = [s]UFConstants.UF_UI_SEL_FEATURE_CYLINDRICAL_FACE[/s] UFConstants.UF_UI_SEL_FEATURE_ANY_FACE
