Journal function don't do what documentation say.
Ehaviv
Computer
Jul 2, 2003
1,012
Hi
This is a revised journal (journal from this forum)
I added these 2 lines
Dim File,Window As ListingWindow.DeviceType
lw.SelectDevice(File, "C:\vita_vme_std\Export\cloning_log.txt")
but the cloning log don't go to the file
instead it still go to the information window.
Can someone give a clue, what wrong.
Thanks in advanced.
Code:
 'Here is a basic code snippet that will add the current displayed assembly to
 'the clone process, apply a naming rule (in this case adding "-"
 'to the end of every component), and define the output folder:
Option Strict Off
Imports System
Imports System.Windows.Forms
Imports NXOpen
Imports NXOpen.Assemblies
Imports NXOpenUI
Imports NXOpenUI.FormUtilities
Imports NXOpen.UF
Module Module1
 Public Sub Main()
        Dim theSession As Session = Session.GetSession()
        Dim theUISession As UI = UI.GetUI
        Dim workPart As Part = theSession.Parts.Work
        Dim displayPart As Part = theSession.Parts.Display
        Dim theUFS As NXOpen.UF.UFSession = NXOpen.UF.UFSession.GetUFSession()
        Dim lw As ListingWindow = theSession.ListingWindow
        Dim Current_Assembly As String = displayPart.FullPath
   Dim cloner As NXOpen.UF.UFClone = theUFS.Clone
        cloner.Terminate()
        cloner.Initialise(NXOpen.UF.UFClone.OperationClass.CloneOperation)
        cloner.SetDefNaming(UFClone.NamingTechnique.NamingRule)
        cloner.SetDefDirectory("C:\vita_vme_std\Export\\Export")
        cloner.AddAssembly(Current_Assembly, Nothing)
        Dim opt As NXOpen.UF.UFClone.ExLogOpts
        opt.allow_missing_components = False
        Dim namerule1 As NXOpen.UF.UFClone.NameRuleDef
        namerule1.type = UFClone.NameRuleType.AppendString
        namerule1.new_string = "-"
        cloner.SetNameRule(namerule1, Nothing)
        cloner.SetDryrun(False)
        cloner.PerformClone(Nothing)
        cloner.Terminate()
 End Sub
 Public Function GetUnloadOption(ByVal dummy As String) As Integer
        'Unloads the image when the NX session terminates
        GetUnloadOption = NXOpen.Session.LibraryUnloadOption.AtTermination
 End Function
End Module
Some example code is below:
Code:
'use listing window to write to file and window
lw.SelectDevice(ListingWindow.DeviceType.FileAndWindow, outputFile)
lw.Open()
'write information to listing window
lw.WriteLine("full path: " & workPart.FullPath)
lw.WriteLine(New String("-", ("full path: " & workPart.FullPath).Length))
lw.WriteLine("file name: " & fileName)
lw.WriteLine("file name w/o extension: " & fileNameNoExt)
lw.WriteLine("parent folder: " & parentFolder)
lw.WriteLine("root folder: " & root)
lw.WriteLine("")
lw.Close()
'flush file buffer by changing listing window device
lw.SelectDevice(ListingWindow.DeviceType.Window, "")
You can find the above code and some more explanation in the article here.
www.nxjournaling.com
Are you mean that adding
lw.open() and the flush command
to my journal will amended the journal.
to my journal will repairs the journal.
Double check the .SelectDevice method. The way you are doing it looks odd to me; I'm not sure why you are declaring a variable as a DeviceType. You should specify the device type from the NXOpen API's enumeration. And, yes, you should change the device type to flush the buffer (which will write the info to the file).
Also note that some operations (such as cloning) may ignore your settings and do what they want. Below are a couple of threads from the Siemens programming forum:
Hi Cowski I'm very thank you for that helpful information.
Maybe I need to live with those pop up cloning reports.
