Hi everybody!
Need an advise on steel heat treatment please. A drawing specifies induction hardening 56-61 HRC with 3mm case depth for a 42CrMo4 steel pin 200mm in diameter. The supplier claims that in this case only hardness 50-55 HRC is achievable. The engineer that made the drawing refers to the standard where for this steel grade the hardness values obtained from Jominy test are 56-61 HRC up to 3mm from the quenched end.
Who is right in this case? Can the specified hardness range can be achieved?
How the Jominy data should be applied in practice treating parts considerably larger than the test specimen?
Many thanks!
Many thanks!
