JOG on leader Dimensions (Solidworks 2007) 1
designmr
230
I am trying to add a jog on a leader of a regular dimension (non-ordinate).
I thought on the earlier versions on Solidworks you could do it. When leader run so CLOSE to together, I looked at moving the dimension to another view, but in this case I am limited.
Any help?
You still cannot add a jog to a dimension leader, as far as I know, but you can to a note leader. You could always create a note, link the dimension value to the note and hide the dimension. You would then be able to add a jog to the note.
Hope this helps.
Steven Danasko
Certified SolidWorks Professional
SolidWorks 2007 - SP2.2
UG NX3
Pro/Engineer Wildfire 2.0
GTCadGuy, well I thought there was, I just got thru using Catia for a year, I think that is where I got it from.
The note way, can you have a note with leaders on both sides?
designmr,
You can have a leader on both sides, but SolidWorks seems to determine if the leader is on one side or both. You can add a second leader and drag the note around to a position where a leader is on both sides.
Hope this helps.
Steven Danasko
UG NX3
Thanks, I'll try it....
Apprecate the help
You can also use the "Mulitjog" leader tool to draw it manually. It will snap to notes but not dimensions.
Jason
SolidWorks 2007 SP4.0 on WinXP SP2
