I am using Rhinoceros (CAD) and Ansys Workbench (FEA). Basically exporting solid models from CAD to FEA. In FEA, the procedure followed is:
1. Giving meaningful names to different geometry components
2. Assigning material
3. Defining contacts
4. Meshing
5. Setting up loads and boundary conditions
6. Setting up analysis properties - large deformation, etc.
Now after the first FEA run if I change something in a geometry component in CAD (example: fillet the sharp edges, increase bolt and hole diameter, etc.) then I have to import the new file in FEA. This leads to repetition of step 1-6. Is there a way to be able to make small geometry changes without repeating all the steps (especially 1 and 3)?
Sushant
4. Meshing
Sushant
