I am looking for a domestic supplier for Italian Grade Metals such as the following:
FeP01 (BS EN 101130)
From my understanding, this hot dipped galvanized material is typically only supplied up to a 2mm thickness. Does anyone know of a supplier other than Parker Steel or Maryland Metrics who might supply this in a thicker size, even if it is an alternate alloy? I also understand that an alternative for this material might be the DX51D+Z (EN 10143).
Thank you!
Thank you!
